SE Race Tuner
I just bought a new SE Tuner and am a little reluctant to try doing it myself.
Has anyone else done this? 06 StreetBob Stage 1 SEII slips/Big City Thunder Baffles |
RE: SE Race Tuner
piece of cake. Just read the instructions, and don't skip any of the steps. pick the map you want to use and just load it. pay attention to when the instructions tell you to turn on the power and when you turn on the ignition switch!! (don't ask me how i know). it really is easy to load a supplied SERT map.
http://i96.photobucket.com/albums/l1...e/DSC03002.jpg |
RE: SE Race Tuner
Where does the data cable go into the bike. ?? is it located in the electrical panel box with the fuses?? Please advise.
RE: SE Race Tuner
Real easy to do. Follow the directions and make sure the run switch is in the on position.
RE: SE Race Tuner
if i remember right, it is slipped onto a little plastic retainer right on the front of the fuze panel. look for a square plastic conncetor, probably with a rubber plug on the end, about dead center on the electrical caddy (fuze panel). once you find it, you're be glad it wasn't a snake as it would have bitten you.
RE: SE Race Tuner
ORIGINAL: 6165hd Where does the data cable go into the bike. ?? is it located in the electrical panel box with the fuses?? Please advise. |
RE: SE Race Tuner
The connector on your bike to hookup your Screamin Eagle Race Tuner is under the fuse box cover on the left side of the bike right next to the ignition coil that your spark plug wires plug into. Use two hands to grab the cover and pull straight out. Connector is grey with a black rubber plug.[/align][/align]
There is only two 'Closed Loop' maps for our bikes, #32 & #59, the difference between the two, one is for8* injectors and the other is for 25* injectors.If you have 25* injectors use the 8* map, it will make it a little more richer, both are richer then the original map but still on the lean side of the spectrum. Hook cable up, ignition switch on, run switch on. Click on Screamin Eagle Tools --> Delphi -->tuning mode,I accept, click on one of the below maps, file, program ECM, select com port, get ECM info, program ECM cal......done Cal #32 -- 141NX002-A0.MT6 Application: 2006 Shotgun / Shorty Dual Exhaust with O2 SensorsConfiguration: 1450 SE A/C & Mufflers Components:8 deg Injectors P/N 27625-06 SE Air Cleaner and Breather Kit P/N 29440-99C SE II Slip-Fit Mufflers P/N 80448-03 or 80258-99A[/align][/align]Cal #59 -- 141NX104-A0.MT6[/align]Application: 2006 Shotgun / Shorty Dual Exhaust with O2 Sensors Configuration: 1450 SE A/C & Mufflers[/align]Components:25 deg Injectors P/N 27709-06 SE Air Cleaner and Breather Kit P/N 29440-99C SE II Slip-Fit Mufflers P/N 80448-03 or 80258-99A[/align][/align] |
RE: SE Race Tuner
Formula, do you use one of those maps?? As is??
mud ORIGINAL: WS6 Formula The connector on your bike to hookup your Screamin Eagle Race Tuner is under the fuse box cover on the left side of the bike right next to the ignition coil that your spark plug wires plug into. Use two hands to grab the cover and pull straight out. Connector is grey with a black rubber plug. [/align] [/align] [align=left]There is only two 'Closed Loop' maps for our bikes, #32 & #59, the difference between the two, one is for8* injectors and the other is for 25* injectors.If you have 25* injectors use the 8* map, it will make it a little more richer, both are richer then the original map but still on the lean side of the spectrum.[/align][align=left][/align][align=left]Hook cable up, ignition switch on, run switch on. Click on Screamin Eagle Tools --> Delphi -->tuning mode,I accept, click on one of the below maps, file, program ECM, select com port, get ECM info, program ECM cal......done[/align][align=left][/align][align=left][/align][align=left]Cal #32 -- 141NX002-A0.MT6[/align]Application: 2006 Shotgun / Shorty Dual Exhaust with O2 Sensors Configuration: 1450 SE A/C & Mufflers Components:8 deg Injectors P/N 27625-06 SE Air Cleaner and Breather Kit P/N 29440-99C SE II Slip-Fit Mufflers P/N 80448-03 or 80258-99A [/align] [/align]Cal #59 -- 141NX104-A0.MT6 [/align]Application: 2006 Shotgun / Shorty Dual Exhaust with O2 Sensors Configuration: 1450 SE A/C & Mufflers [/align]Components:25 deg Injectors P/N 27709-06 SE Air Cleaner and Breather Kit P/N 29440-99C SE II Slip-Fit Mufflers P/N 80448-03 or 80258-99A [/align] [/align] |
RE: SE Race Tuner
Mud, I used something similar from below for the 2 into 1 exhaust.....These are map settings that were sent to me from another forum member. He saidthat he sent them to several other members that had good results with 8* & 25* injectors and aftermarket or Screamin Eagle exhaust systems. You can put these figures into Cal #59 -- 141NX104-A0.MT6. If anyone trys these out, try out both VE settings that I listed below (richer & Leaner).
Air Fuel Ratio 13.613.613.413.613.813.313.012.412.411.011.011.0 13.613.613.413.813.813.313.012.412.411.011.011.0 13.713.714.614.614.614.614.613.213.211.011.011.0 13.713.714.614.614.614.614.613.213.213.213.213.2 13.713.714.614.614.614.614.613.313.313.213.213.2 14.114.114.614.614.614.614.613.313.313.213.213.2 14.114.114.614.614.614.614.613.313.313.213.213.2 14.114.114.614.614.614.614.613.313.313.213.213.2 14.114.114.614.614.614.614.613.313.313.213.213.2 14.114.114.614.614.614.614.613.313.313.213.213.2 13.713.714.614.614.614.613.813.313.313.213.213.2 13.313.313.513.513.613.513.313.313.313.213.213.2 13.313.313.313.313.313.313.313.313.313.213.213.2 13.313.313.313.313.313.313.313.313.313.213.213.2 13.313.313.313.313.313.313.313.313.313.213.213.2 13.313.313.313.313.313.313.313.313.313.213.213.2 13.313.313.313.313.313.313.313.313.313.213.213.2 VE Front Cyl (Richer) 83.084.585.085.586.086.585.083.081.581.081.081.081 .0 83.085.086.086.087.087.586.084.082.082.082.082.082 .0 83.086.588.088.589.590.087.586.083.083.083.082.082 .0 85.587.589.089.590.591.591.089.085.085.085.084.584 .0 87.089.592.593.094.595.594.592.087.587.087.586.586 .5 89.091.094.095.598.5100.598.595.593.091.091.090.58 7.0 89.090.593.595.599.5101.0100.098.594.093.092.091.0 88.5 95.591.596.098.0102.0102.5104.5105.0103.098.598.59 9.098.5 100.594.097.5101.0104.5105.5107.5111.0108.5101.010 0.5102.0101.5 101.596.599.0102.5107.5109.0112.5116.5114.5103.510 1.0102.5101.5 105.5101.5100.5102.5108.5109.511 |
RE: SE Race Tuner
Amazing,,,,, Thanks for sharing the information.. now if i get the balls to really do it, I will let you know.............
© 2024 MH Sub I, LLC dba Internet Brands
