FXDLS stock riser bolt size?
This is a Dyna forum. 2020 Low Rider S (FXLRS) is a Softail, not a Dyna. Totally different triple tree - 59mm inverted fork on Softail vs. 49mm standard tubes on the Dyna.
2016-17 Dyna Low Rider S (FXDLS) stock riser bolts are spec’d as 1/2”-13 x 2 3/4” grade 5. Though a 3” grade 8 from Ace or any hardware store should work fine, especially if you are using aftermarket bars and/or poly bushings which don’t compress quite as much.
Perfect, exactly what I needed to know, thank you.
And to clarify for any future searches; 2017 Dyna Lowrider S. I was looking for the 2 bolts that connect the risers to the triple tree.
Thanks again
Thanks again
https://shop.suburbanharley.com/oem-parts#
Harley-Davidson >> 2017 >> DYNA >> FXDLS 1GS8 DYNA LOW RIDER S (2017) >> HANDLEBAR
https://shop.suburbanharley.com/oem-...259353a5a1f4/y
What is the size of the oem riser on the dyna low rider s? Just realised mine is unlikely to be oem. Mine is a 6.5 inch pullback riser and I want another 2-3 inches length.
I've seen all the posts about using riser extensions on the oem risers and how the 3 inch works but until I know the length of the oem risers, I don’t know if I can extend by 3 inches without extending the clutch cable
You can lookup parts here:
