Cylinder head Exhaust stud torque value?
Old 10-27-2022, 12:41 PM
WrenchThrower's Avatar
WrenchThrower
WrenchThrower is offline
Stage III
Default Cylinder head Exhaust stud torque value?
Hi, I’ve looked through my manual and various threads here, but cannot find any mention of what to torque the exhaust port flange stud to…(?)
I have a new stud after removing the original when the nut would not come off. I’m planning on using Anti-seize on the new one and the nuts. This is on an ‘03 Superglide if that matters. Thanks in advance for any help.
Old 10-27-2022, 01:30 PM
QC's Avatar
QC
QC is offline
Received 19,788 Likes on 9,863 Posts
10-15 lb/ft.
not much more than hand tight. Run it around the block a few times then re-torque after it cools down.
Check occasionally.
M Oclaf (10-30-2022)
Old 10-27-2022, 07:43 PM
Bluesrider.df's Avatar
Bluesrider.df
Bluesrider.df is offline
Received 1,663 Likes on 936 Posts
Mine continually came loose so I used double nuts on each of them.
Old 10-28-2022, 03:51 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Received 1,115 Likes on 629 Posts
Feeling and good judgement are better friends here than any torque wrench will ever be .
The following 2 users liked this post by Midpegs:
eighteight (10-28-2022), M Oclaf (10-30-2022)
Old 10-28-2022, 04:56 AM
Schex's Avatar
Schex
Schex is online now
Received 6,834 Likes on 1,769 Posts
agree, a torque wrench in the wrong hands,,,,
Old 10-28-2022, 06:21 AM
WrenchThrower
Stage III
Thank you gentlemen, warning taken… just was somewhat surprised I couldn’t find anything in the Bible… nuts and sequence, yeah, but nothing specifically for the stud itself.
It came out so easy, and obviously not much put on it at the motor co. Thanks again.
Old 10-29-2022, 09:29 AM
John CC's Avatar
John CC
John CC is offline
Studs are supposed to have a slight interference fit. That's what keeps them in when you loosen the nut. If it's a replacement then it may be loose. Some studs are available in oversize for that purpose; don't know if Harley has that or not. You may be able to find an aftermarket one.
If it wasn't an exhaust stud you could try Loctite, but in this case, Loctite probably won't help; the heat is too high.
Old 10-29-2022, 09:49 AM
Rounders's Avatar
Rounders
Rounders is online now
Received 1,858 Likes on 1,466 Posts
Cannot agree. Someone with zero experience is better of using a tq wrench. I will also say experienced guys guessing, is just a guess.
Only thing that bothered me tq is one time I tried to tq spak plug out of curosity. It just felt like to much. But I did have one blow out, and maybe if properly tqed it would not have. I replaced a ton of them riding snowmobile, so spare me any lectures.
What I do attribute the plug coming loose to, it had 10k miles on it. If I would have replaced, it would not have happened.
Old 10-29-2022, 09:50 AM
Rounders's Avatar
Rounders
I think some people are missing he replaced the stud that goes into the head. I believe.
Old 10-30-2022, 07:12 AM
Midpegs's Avatar
Midpegs
Midpegs is offline
Right , so when they wrote Flange Stud they meant Flange NUT . On the assumption that you have fitted new graphite / mesh Crush Gaskets , you need to tighten the nuts evenly until you feel ( That word again ) the header embedding into the gasket sufficiently to create a gas proof seal . The reason HD do not give a torque setting for this operation is that you are not bolting metal to metal and therefore no reliable setting can be given .
Quick Reply: Cylinder head Exhaust stud torque value?
