chrome pinch bolts?
thanks, paul
i just called my local dealer and they're telling me that part number 4351is a 5/16 x 3/4 bolt ....???... and honestly, i didn't even want to argue with those girls behind the counter... i argue with them, regularly, and i'm always right.... i just don't have the energy, today.... do you have the specs on that pinch bolt, and i'll just buy some from chrombolt.com
thanks!... paul
...thanks, man....and indeed, i'll confirm before i order
short story about the girls at this dealership behind the counter:
...actually went there with one of the molex plugs IN MY HAND that i'd pulled apart from the end of the wiring harness for my right hand switches... i'd accidentally damaged it pulling out the terminals to swap out my handlebars....anyway, i had it IN MY HAND and the girl tells me that it didn't come off my '07 street bob and that it must have come off a different bike... i look at her with a look on my face as if to ask "are you okay?" .... cause i know i'm riding an '07 dyna...it is a street bob...and it does have a 96inch motor in it....long story short, we went back and forth for nearly 20 minutes before she decides to talk to the mechanic out back who'd apparently convinced her that i really had no reason to lie, and was probably pretty sure about what i was riding.... so as she's laboring over her computer and catalog, he shows up with 2 brand new ones in packages!
has happened about a half-dozen times..... unreal
According to the Harley parts catalog the pinch bolt # 4351 is a Torx Screw, 5/16-18 X 3/4 (gr. 8) (self tapping w/lockpatch)
Hope this helps you.
Bart
[IMG]local://upfiles/16365/D2AD6785B8484EAC8E64B00A6D5EFC4F.jpg[/IMG]
[IMG]local://upfiles/16365/B91029B0D1904099AF9AC0F644823E90.jpg[/IMG]
[IMG]local://upfiles/16365/4E5BB448F3BD4929B45508DB51D7103D.jpg[/IMG]
...and a 3/8 X 16 cap screw....just to check size, pitch, and length before ordering from chromebolt.com, and the 5/16th is NOT the bolt for the triple clamps....but YES, the original I remember WAS a torx screw and WAS self tapping.... but it definitely is 3/8, and must at LEAST be 1 1/4 inch long...
...a 3/4 inch bolt won't even make it through all the way and the 5/16 is just too skinny!
something is up ...i mean, jmpancoast even went out and pulled one for me to verify... and it's not the size the parts catalog is saying it is
I'm doing my front end to and I bought S/S socket head caps screws like's on 3/4 of the Bob...
Self taping???.....Why.......the threads are there in the new wide glide trees...
[IMG]local://upfiles/23685/20A6C2380B5C4A8B8E4968F8064FCB00.jpg[/IMG]
so that's what i'm doing....i bought the stock pinch bolts to create the 16 pitch thread, and then i'll just back them out and replace them with standard chrome button heads
By the way js1268......What wheel are you gonna run once you get your trees changed??
That's where I'm having a problem....
I wanna run my 19 stock tire....
So far no spacer is around for that yet
I was even thinking of spacing just the caliper....
I'm looking into a bunch of different things
[IMG]local://upfiles/23685/BC35A49469944276BDDAFCB762CD1EFD.jpg[/IMG]
