problems fitting risers
i wish to fit 4.5" risers to my 2002 wide glide with stockmini apes will i have problems with the wiring being long enoughand do you think i will get away without replacing any of the cables.
thanks all |
RE: problems fitting risers
give it a go... yoiu should have enough there in cables... the thing you have to worry about is the brake lines... you can bend those strait and be cool i bet... give it a try... if not you will have to get cables anyway
i tried and no go so i went with 2and 1/2 with no problems,
what problem did you have?..was it with all the cables or wiring or both
i have said this a bunch but only cause it works... you can also measure out to see the max you can do on a rise and then just make your own risers wiht stuff you find at homedepot... i can walk you though it, it is crazy easy and cost like 5 bucks! plus it looks great!
Buddy of mine did 4.5 on a street bob with NP and like Joe said he had to bend straight the brake line. I put 12 in apes on my low rider, same thing.
hello mate, i must admit i am mostintrigued about these risers you made for yourself please tell me how
it is pretty simple really... you just run to the hardware store, get some fender washers, and 2 hardend bolts... from there go over to plumbing and get some chrome pipe (the kind you have under your sink... then just get a push cap that fits... cut the pipe to lenght (tape it off to keep the chrome from flaking) drill a hole in the center of the push cap, then just count out the washers to match what you are going for... works tops! i have done it many many times! here are a few pics
[IMG]local://upfiles/26534/F7BB2E4E8117459E9C17FAC6A43BE3F5.jpg[/IMG] [IMG]local://upfiles/26534/667ADE6760264238A63FFB52A9ED1D46.jpg[/IMG] |
ok thanks for that may give it a go
4.5" risers fitted no problem a nd they look real nice............yes...........
© 2024 MH Sub I, LLC dba Internet Brands
