Wanna know others results.............
Wasn't satisfied with Vance and Hines fuel pac, as I mentioned before it was my second one..............soooooo, when my 5000 mi service came up I thought hmmmmmmmmm !! So I purchased a Techlusion Stealth Unit from the steeler, had it dyno'ed and here are the results and I would like to hear what others got when they had theirs done............
With Vance and Hines I got 74.71 hp and 76.29 torque.........With Techlusion it turned out 77.45 hp and 80.13 torque plus the air/fuel is matched all the way up the rpm scale, with the V&H it wasnt.............just a normal 06 Street Bob, stage one naturally.........wayyyyyyy happy not to have the decel poppin and smooth crisp throttle response even at slow rpm while crusin chicks, hahahahaha
I don't think there are a lot of folks on this forum using the Techlusion; most have PCIII, FuelPak, or SERT (if anything). I'm not saying there's anything wrong with that unit, just that you may not have a lot of other folks' results to compare to. However, the important thing is the A/F ratio is good all the way across and you're happy with the way it runs.
Was just wonderin.............
Understand all the above, was just wondering what other Street Bobs ran out at. Tech is from Dobeck performance, wasnt havin luck with FuelPak and jus wanted something more.....air fuel is better as well as torque, all are basically the same plus or minus, add this value add that value..............jus a simple question.
