**DYNO SHEETS* and/or *1/4 MILE TICKETS**
Not a bad idea, although I don't think dyno #s mean much, as there's so many variables, but I'll contribute!
Vance and Hines Slip-ons
Screamin Eagle AC
Techlusion TFI 1250st set at Green-4:15 Yellow-4:15 Red-6:45 RPM-3:50
Max power = 72.56
Max Torque= 83.76
Screamin Eagle AC
Max power = 72.56
Max Torque= 83.76
D&D Fatcat, Heavy Breather, SERT. I personally think the HP is a little low, so I may find a new tuner.
Well, I had the SERT installed with a dyno tune today, and I'm not impressed with both the numbers and the bike...the a/f ratio looks ok but it's popping and backfiring worse than ever. The tuner spent just a little over an hour with the bike, including a test ride afterwards. I thought he was gonna continue with the tuning, but he was done.
I was charged for 2.6 hrs @ $95.00 per hour...they were done with the bike in an hour and a half.
I had changed to the round multi fit SE backing plate and a Zippers filter, but I'm thinkin' now I may go back to the '08-'09 SE Dyna backing plate per my sig pic with a K&N filter for it. I had very little popping with that set up...
I've said it before, a good mechanic/tuner is worth their weight in gold. Maybe I'll get lucky and find one for the bike.
Here's mine with V&H Big Radius, BCT baffles, RSD A/C, PCIII. My AFR is not on there but it's pretty flat straigt across. I just installed HQ500 cams & we got about 80% done tuning & then my rocker box cover developed a leak so we called it a day. Hoping to finish everything today & I'll post another chart of before & after.
