Heavy breather air filters - different colors?
Bingo!
There was a thread lately about a guy that washed his K&N and let it fade out, then treated it with blue filter oil. looked good!
Oil that was used:
http://store.summitracing.com/partde...5&autoview=sku
Oil that was used:
Use a cleaning solution made for that type of filter. Some spray on, some soak it. Whichever you choose, let it soak it for about 10-15 minutes. (Some people have used simple green successfully)
Remove it and rinse with low pressure cool water from the inside out.
Let it air dry, don't use pressurized air.
Reapply the oil, and make it even and the same color all over. View from the inside out if you can, and check the coverage. Try not to over oil. Won't hurt too much if you do, just may have to clean your MAP sensor later, 'cause of the oil residue.
That's pretty much it
Deck
