relocated my signal lights
I bought a solo seat so I moved the signal lights to the tag/tail light with a chrome light bar from J&P. The problem now is that I don't like how the wires are out in the open. Anyone have a solution to make this a better project? Check out the pics.
Thanks guys,
Tim
Thanks guys,
Tim
I decided to get the tail light relocation/lay down license plate. The wires are hidden in the chrome tube that holds the signals. Really like the design. Not sure what to tell you since you have already gone the route you did. You are not going to get away from seeing the wires. Even if you go with flex tubing/shrink wrap you will still have that exposed since you used a flat plate to mount your lights. Good thing is you are the only one that will really see it since you did a good job hiding it behind the plate.
joshag
04-15-2018 05:10 AM
