Tying bike down on a trailer
08 Super Glide Custom, I am taking my bike to Maine in a couple of weeks, I live in Ct and decided rent a Motorcycle trailer from Uhaul for the 8 hour trip and I could use some advice
on tying it down. The Uhaul trailers have a built in tire chock and lots of tie downs. Were is most secure area on the bike tie it down. Thanks for any help.
Begin by using some soft straps through the triple trees, secured by ratchet straps. Tighten enough to compress your forks. How much is open to debate, but you want to make sure the bike doesn't lean or the bars can't move. Also tie down the rear end to prevent it from sliding. In the photos below I slid my straps around the lower frame, but I've since began strapping it further back by the lower shocks.
I can attest to what the other 2 say. Take their advise..... dont do what mine did.
Picture 2 bikes....Both with limited edition Custom colors. One is brand new with 5 factory miles on it. The other is a year old. Picture opening up the trailer door after 160 miles to find one that had shifted and was laying against the other, probably bouncing and wiggling for the entire trip. Picture one with the windshield gouged and scratched a to hell and on the other, the tank dented, and scratched gouged down to the primer.
Now get the news that the tank could not be repainted because Harley doesn't sell limited edition custom paints in sufficient quantity to repaint the tank, and the Factory wont accept damaged tanks for repair or repainting. You have to buy a whole tank, to the tune of $999....plus install. Picture replacing the windshield on the other.....another $350. Why.....because my hubby didnt PROPERLY TIE DOWN THE BIKES, NOR DID HE STOP TO CHECK ON THEM DURING THE HAUL.
Expensive lesson learned on that first trip trailering bikes.
Oh......and be sure you warp a soft cloth under the straps, so it doesnt rub against any painted areas!!! VERY IMPORTANT, or the straps could leave marks.
Hey Jake.......I see you have the Condor chock set up on your trailer......same as ours!!!
If I have to take mine to the shop on my trailer, I use soft straps and hook them around the handle bars and the risers. The rear 2 go throught the upper part of the shocks. Always use the wratching kind...I never the motorcycle/ATV type...(they'll hold but they can slip). I check them once at the end of my road, once about a mile down the road. Best to use a front wheel chock (optional but good insurance). Keep them cranked down. I'm a big guy and I crank those wratchets until I can't get them down any more.
I think the trick to trailering is keep the front tire from moving. I usually tie the tire to the chalk, then use a couple around the handle bars and down. I welded a 18" angle iron to each side of my wheel chock right at the front axle for this. Pull the bike down maybe 2 inches but don't bottom the forks. Then just keep the rear tire from sliding. I go to the rear of my sled trailer for this. Make sure that you have solid tie down points. Because the bike is riding on its suspension, I tyrap or tape any hooks closed. But again, I think the trick is to keep the front tire from moving.
If you have ever tied a boat to a dock then tieing off a bike is similar in that you spring the straps against each other so the bike cannot move in either direction. Front straps pulled to the rear with some tension, rear straps pulled to the front and side straps pulled against each other as well. I use 6 straps to tie my bike. Compress the fork 2-3". The rear straps should hold the front tire in the chock and stabilize the rear end as well.
Be sure to pad the straps as advised above as they will damage paint. If you are in doubt, add 2 more straps. I have seen guys use as many as 8.
