1995 to 2005??????? TANK HELP
OK i have a 2005 FXDX, i want the gauges on the tank, NOT on the tree.
I found a 1995 FXDL tank with dash and gauges that will be perfect on EBAY, my only question is will it fit. I believe from looking on line the tanks can fit any Dyna from '95 to '05. Can anyone confirm or discount this?
Thanks for the help guys.
all of the above answers are correct.
even if you don't have FI - any tank before 04 will not fit properly with your seat - among other things.
all tanks 04 and later from ALL dyna models will fit - but you will have dash issues.
cheapest path is a St Bob tank - that way you can reuse your speedo - but you will need a new idiot lamp cluster, dash, fuel gauge, etc.
as mentioned - the WG tank is a great alternative - but involves the added expense of a new speedo (also the wg idiot cluster, dash and dash panel).
what you need to understand is that this is no way a cheap transition. Even with a great deal on a tank - there are lots of dash and other parts to buy that rarely show up on the used (ebay) market.
also - you need to be proficient with wiring.
rladkins
04-06-2006 01:28 PM
