Best way to disassemble turn sigs for powder?
Just wondering wht the best way to disassemble the rear turn signals for powder coating is? you cant pull the wires through the stems cuz the connector is too big....do I need some sort of tool to get the wires out of the connector or is it easier to just cut the wires then solder them back together later?
In the meantime anyone with a quick answer to this - info is appreciated. |
small screwdrive will pop out the inner chrome cap, pull out, cut the wires... powder them... solder the wires, shrink wrap them and put em back togehter... just got done doing 8 sets last night! i do them ALOT
Originally Posted by CRF
(Post 5754057)
your links dont' seem to work; but I'll have a look for the info.
Originally Posted by mud
(Post 2700467)
I've received several emails over the last two years asking about
extracting wires from the ever so popular AMP connectors. HD uses these in several locations on their machines. Here's the last one: mud, I picked up the short standoffs at the dealer today and wanted to install them tonight but am unsure about the process. Someone on the forum said you cut the wire for each signal and splice into it, but the directions don't say anything to that effect. They mention something about undoing the plug from the rear tail light area instead. I've never done any electrical work on my bike before so I'm not really sure if these mod is out of my league. Any chance you might be able to decipher the instructions and give me some tips on doing the install? Thanks, ******, yeah nice to hear from you. I am a strong believer in NOT cutting wires. Yes, remove the lens, then unplug the fitting. Really very simple to disassemble the electrical connectors so you can pull the wires thru the standoffs. I've heard quite a few folks on the forums brag on how fast they can cut the wire and then solder. Sadly, that bit of misinformation is a joke. I can extract several before you can even get out the snips, soldering gun, solder, shrink wrap, heat gun, etc. Patience is a virtue while mastering this technique on the first wire. After that, they get easier. I can release them in a matter of seconds now. Same is true for the other connectors that HD uses - Deutsch, Packard, Delphi - NO need to BUY SPECIAL extraction tools for any of these. Here ya go: Remove the two screws that hold the taillight to it's housing. Use a small screwdriver to push the lock tab down a little, and pull the fitting out. . . http://img294.imageshack.us/img294/4...ttingremov.jpg . . This image below shows the 2 hole AMP and the tip of the 16 gauge wire I use. Blue arrow shows a slight bend, and the tip is hammered flat. Red is the first lock to undo. This is what holds the wires in the fitting. Green is the tab that you released in the first step above, it locks the fitting to it's receiver. Green on the right is opened way up for some of the pix farther down. Don't bend it out or you will ruin the fitting. They are cheap, fifty cents or so. . . http://img294.imageshack.us/img294/1...ttingpartn.jpg . . Blue below, better shot of the 16 ga tip. . . http://img294.imageshack.us/img294/5...ttingrelea.jpg . . Next image you see I put an S bend in my release tool so I can control it better. Also here you see that I have the turn indicator wire pushed fully IN while raising the lock tang inside. . . http://img294.imageshack.us/img294/7...tting1382e.jpg . . Now, below, once you have the lock tang lifted, extract the wire. . . http://img228.imageshack.us/img228/7...tting1383e.jpg . . Don't forget to pay attention to which wire comes from which side of the fitting. There are small numbers on the housing. In this case. 1 is purple, 2 is black. Next two images illustrate where the tang is, and where the tip of my tool needs to be. Green is pulled way up here simply for the photo. . . http://img228.imageshack.us/img228/3...tting1976i.jpg . . I suggest buying a couple of new sockets so you can fold this way wide open for your first try at this. If need be. Little blue arrow indicates how far the end of the tang lifting wire needs to be. . . http://img100.imageshack.us/img100/9...tting1976i.jpg . . . Here's the tool:
Originally Posted by FXD2003Rider
(Post 5696573)
When I relocated the front turn signals to the base of the aux lights on my 2003FXD, I had to pull out the socket assembly from the turn signal housing.
http://i695.photobucket.com/albums/v...Dynafront3.jpg I was worried to cause damage to the socket assembly by using a screw driver; therefor I made a "socket assembly extraction tool" out of a metal coat-hanger. You simply squeeze it, hook up the pins into the notches where the bulb fits in................ http://i695.photobucket.com/albums/v...ctiontool2.jpg . .........and pull out gently the socket assembly: http://i695.photobucket.com/albums/v...ctiontool3.jpg ___________ FXD2003Rider |
Originally Posted by JRK5892
(Post 5754126)
© 2024 MH Sub I, LLC dba Internet Brands
