turn signal running light kit
do you have to buy that kits that makes your turn signals work as tail light brake light or can you wire it some way. thanks
run brake turn kit. Available at stealer. module goes under the seat and you change the orange signal covers for the red ones. I think it's about 50 bucks or so.
It plugs 'in line' (plug-N-play, as they say) with the rear wiring plug under the seat. Lots of people use it with the factory brake light for additional visability to the traffic behind you.
Originally Posted by moonsfmc
(Post 5758083)
The rear signals are single element so no way to wire it yourself unless you replace the signals with a dual element one (one guy on here did do that) but probally just as much money to do that and alot more time. It really makes a nice difference. http://i4.photobucket.com/albums/y10...glide047-1.jpg |
Buy the Harley module. It's available at any Harley dealer. Including taking off and putting the seat back on, plugging in the module and changing the turn signal lenses from amber to red; it took me 15 minutes. But 10 minutes of that was because I had to readjust my FuelPak which is also stowed under the seat. This is a must do improvement for safety.
I have had two of the HD controllers and they both have messed up. I'm done with them.
Originally Posted by freedub2003
(Post 5759556)
I contacted Biketronics twice via email before my purchase and they got back with me quickly and were very helpful. |
Will it work with led bulbs?
Originally Posted by Titan56
(Post 5760624)
I'm not using this one, but I'm a big fan of Badlands products.
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm EDIT - It's a run/turn/brake & load equalizer all wrapped up into 1 plug-n-play unit |
© 2024 MH Sub I, LLC dba Internet Brands
