Anyone relocated the fuel pump yet?
anyone with a fuel injected dyna managed to relocate the fuel pump either outside the tank or found a smaller tank that will accept the fuel pump?
The fuel pump is pressurized. You can't run it out side the tank.
a sportster tank will accept a fuel pump. Not so sure about being able to install on your bike though. Guess it depends on your fabrication skills, or on the skills of a custom shop that could make it work for you.
Check this out:
http://www.cas4.com/HARLEY-EFI/FUEL-...el-pump-01.htm |
Yikes ...! $550 for just the case mounting box ... I guess if you gut your take-off tank you'll have the other $365 worth of parts ....
I didn't see where it showed the dimensions ... might kinda stick out if you were trying to do a 'frisco' tank ... maybe you could mount it on the upper motor mount where the cow bell horn is and conceal it behind a 'cow bell' ...? ... hey maybe you could conceal it inside your fuel tank ... Cool that someone came up with that, but a little pricey .... R/ 'Chop |
i don't mind the tank that's on the bike that much
i had to take off the console though and i'm gonna have to cut the mounting brackets for the speedo off. maybe i'll have to try my hand at tank beating 101 |
how exactly does it mount in the tank? a sporty tanks are easy enough to come by and have the look i want. so that's a definite possibility i suppose
Wouldn't one of the new sportster tanks work? they already have the fuel pump in the tank..........should be just a matter of figuring out how to mount it.
I was at a bike show a couple of weeks ago and I saw a brand new Xbones with a sportster tank on it at a dealer's display - looked cool. How much more difficult would it be to do that to a dyna? |
BTW, if you want to sell the guts out of your tank, let me know. Or if anyone else has pump/float guts...
Originally Posted by Bobbed Out
(Post 6195224)
(Post 6195228)
My point in my previous post is that to get a 'clean' looking build, you would need to conceal or disguise the fuel pump (that had been removed from its previous--unseen--location inside the fuel tank) ....
Originally Posted by CRF
(Post 6195257)
I was at a bike show a couple of weeks ago and I saw a brand new Xbones with a sportster tank on it at a dealer's display - looked cool. How much more difficult would it be to do that to a dyna? Now, if you want a more radical look ... peanut tank ... mustang tank ... then you would have to get creative or start looking at high-dollar custom tank work .... R/ 'Chop |
© 2024 MH Sub I, LLC dba Internet Brands
