Best bolt in cam
for strong low end...andrews 26 gear drive... for the bike to come on over 3K rpm, andrews 37, supposedly the woods works really good with a 4deg advance gear with the tw6. Definitely recommend gear drive, extra 4-5 hp over chain driven cams is the norm. both cams can easily match head work and larger displacement.
SE 255: Low cost. Get new take outs for around $150 on eBay. Have seen them sell for a $100 used on the Forum. Bolt in. Strong bottom end that comes on early. Power quits too early for some riders. Popular cam for 96 inchers on another Harley forum.
When you go bigger you make want to replace the 255 with a cam that lasts longer. More cubes will give you more torque so your cam may not have to come on so earlier.
If you decide on the SE 255 PM me. I have a set out of a 110 kit for an '07 Dyna that I am not going to use when the kit gets installed. Why am I not going to use it? More cubes = More torque.
Gear drive cams are a good option but think about the added cost because most gear drive setups require no less than .0001" crank runout. If your crank is running more than that then you'll need to split the cases, remove the crank and send it out to get trued and welded. Certainly not a bad idea for the long haul but if someone was just looking for some quick bolt-in performance I don't see this as a viable option right off the bat.
I just installed a set of Wood TW6-6 cams in my '07. I've been having trouble finding a good map to use but from what I can tell, they give a good SOTP (seat of the pants) test in my book. You could also look into the TW5-6. Hi lift version that will still utilize the stock heads. I wouldn't mind giving those a try.
the only thing fuel pak has is a map for the 26's. kinda a weak cam with all thats available. more of a bagger cam. sux i know but if you want any upgrades ditch the fuel pak.....thats what I am doing.....tomorrow infact. cams are all over the place but i suggest 37h, or 57h, or tw6-6, ect. it would be much better to do cams and headwork, keep stock push rods and get a real tuner, tts, sert, or hell a pcv.
Also, I love the lope the tw6-6 gives. Here is a video of my bike:
http://www.youtube.com/watch?v=zQT2mMQEaqw
Don't pay attention to the low rpm hesitation. I had a bad map from Fuelmoto. I downloaded the SE211 map from powercommander and that hesitation is almost gone.
Also, if you think about it you don't find too many Wood cams for sale used. You do find a lot of Andrews cams for sale used for one reason or another.
I've tried asking all over this site and not one person has a map they are willing to offer up.
I just find it hard to believe, since there are hundreds of late model harley's with the 96" motor and I'm sure a good percentage have that cam. Only issue is that a lot of those people have alternative tuners (sert,etc). I don't know if you get someone to copy the values and send them to you. You can manually create the map.
