shock questions
I have a 96 wide glide with stock shocks. I wanted to lower the rear a little to make it look better.... I am getting confused with all of the progressive shock models...
I am not wanting to super slam the bike, just lower it a little but keep a decent ride. The more I read, the more I get confused.. Any help would be appreciated. Thanks, J |
Maybe we can help!
Your bike should have a 12.5" eye2eye shock on it from the factory. Your choice of suspension depends on your riding style and load. The 412 Series in an 11.5" or 12" is an inexpensive alternative to stock stuff (well under $300 for the pair) and superior ride quality to the stockers. http://www.progressivesuspension.com...ies/index.html We also see a lot of the 430 Series on Dynas and it's one of our favorite setups for that chassis. Easily adjustable preload (hand turn top cap) and a high end damper make a great rider as well as pretty cool looking. http://www.progressivesuspension.com...ies/index.html Both are available in black or chrome as well as standard rate or heavy duty springs. That help? |
I'm running 12" Progressive 412's on my '96.
They will drop your rear about an inch. http://i260.photobucket.com/albums/i...G/DSC_0168.jpg |
1 Attachment(s)
I now have the 430's on my ride and it's so much smoother. I came from the 418's. I didn't think their would be that much difference but their was.
A 12" shock will lower the bike nicely and not hurt your ride quality all that much. I would suggest Works performance, Ohlin or Ricor for shocks. If you want a chrome or polished shock, Works is the way to go. For black or contrast, go with Ricor. Ohlins for the menacing all business look. If you buy any of the progressives the ride will be 1000 times worse than either of these three manufacturers in comparison.
Really, a 1000?
Originally Posted by rounder
(Post 6926292)
Originally Posted by Progressive Suspension
(Post 6930651)
Really, a 1000?
Read my posts , ever since i installed progressives i have had 2 bolts shear off , as of right now i have a stripped hole in my frame NEVER AGAIN !! Garbage !!! |
(Post 6930651)
Really, a 1000?
I completely agree. I tried Progressives, Works, the remote resevoir Ohlins, and finally the RICORS on my 2007 FXD. The Ohlins and RICORS are, in my opinion, far better than the others, in a class by themselves. The RICORS are cheaper than the OHLINS (the top zoot Ohlins retail at $1450/set, but can be found for maybe $1,000-1100). I think the RICORS are a few hundred less, but not sure.
(Post 6926292)
Buy some lowering blocks. They are 60ish dollars and lower the bike just fine. Then save up for good shocks. Yeah, 412's are NOT the best shocks on earth, but their price reflects that. They are better than worn out Showa's. Progressive has higher end shocks, but they cost more money, and they still aren't 1200 freakin' dollars. If you want the best of the best, expect to pay for it. Till then, give the lowering blocks a try.
© 2024 MH Sub I, LLC dba Internet Brands
