TIGHT BRAKE PAD!! (wheel does not turn)
Did you take the brake caliper apart at all?
Did you get the spacers back in in the correct place?
Did you happen to pry the pads apart before putting the wheel back on?
Try doing it now and then operate the brakes a few times and see if that helps.
First, follow 8541hog's instructions. Thats the best starting point
Question... Did you remove the caliper to install the wheel? If so, could you have possibly crossthreaded the slider pin? (Will cause the caliper to skew and bind the pads, though usually not enough to lock up the wheel)
And, did you make sure the pads were where they belong? If the leading edge dropped out (inner or outer, or both), that can cause binding too.
As for the spacers on the FB… one is obviously longer than the other. The short one goes with the caliper bracket, the longer (which is about the same as the shorter + the bracket) goes on the drive side.
I don’t think the wheel would go back on if the spacers were switched.
Take a look (from the drive side) at the 'leading edge' of that inside pad.
Thanks for all your help!
Looks like pistons and metal rings around that on calipar are popping out more than necessary. I guess I accidentally pressed brake pedal. Don't they go back to normal seating position easily? Do I need to disassemble calipar?
Another thing, accessing top of reservoir is difficult! Do I need to disassemble whole thing to open a cap of reservoir?
Use a 'C' clamp.
