What is this connector
RE: What is this connector
ORIGINAL: kuleli
hi guys,
I live in europa. and have 2006 wide glide. So I have the same problem. What should I do with this cables ? I bought se a/c but cannot install because dealer does not know what to do w
th this cables ? may we zip tie it behind the new back plate ? I am afraid to see error code....
helps are appreciated
06 wg hdi
hi guys,
06 wg hdi
ORIGINAL: Funkhousert
Might I ask how to do that using the SERT?
Thanks
Thanks
The other one, ACR, is for Automatic Compression Releases.
[IMG]local://upfiles/2952/A718C287D9224217A66FE30532B1C3CC.jpg[/IMG]
hi
I asked my hd dealer. he said even if he erase error code it appears again. so I really do not know how to manage this situation.active intake bypass is for 2007 and 2008 models. mine is 2006 and wonder if it fits or not. I do not want to pay it if useless. I need here someone in europa who had installed the kit without problem.
desparately looking for help
Location: Back in the Good Ole USA. South Carolina to be exact.
Go to theVTwin Mania link and look at the bottom where it says Contact V-Twin Mania Click that link. They will likely be able to tell you if that device will work on your year/model bike. You will be more likely to get an answer than posting your question on their site as a review.
http://www.vtwinmania.co.uk/product_...oducts_id=1314
DynoJet makes one, Part # 76423022 Go here http://www.dynojet.com/and do the same thing.
