New 25 degree fuel injectors & stage -I download
Looking for input and feedback and insight - I recently had the 25 degree injectors installed on my 2006 dyna wideglide per MS-1185. I also have SE a/c and SE slip-ons. They installed a Stage-I download (25 degree deg digital) # 34361-06/DT. I recently read of another download # 34385-06 for 25 degree injectors, SE a/c and pro performance exhaust. Wondering if i received the correct download? thx y'all, this is new for me and just want to make sure my baby is going to run optimally.
Your best bet would be to ask your dealer about the alternate download. Chances are you got the standard Stage 1 download which should work fine for most situations, but if they have one which covers your specific components, it might be better for you.
Are you having any problems currently?
Oh, dynarule, M1185 only pertains to all 2006 Big Twins. They came stock with 8* injectors which led to problems of the bike stalling in idle situations when the motor is hot, and some other symptoms. The fix is to replace the 8* with 25* and recalibrate the ECM for the new injectors.
My 06 Street Glide was in the shop three times for that problem before the bulletin came out. Once the bulletin came out they switched the injectors and did the download, no more problem.
[/quote]Oh, dynarule, M1185 only pertains to all 2006 Big Twins. They came stock with 8* injectors which led to problems of the bike stalling in idle situations when the motor is hot, and some other symptoms. The fix is to replace the 8* with 25* and recalibrate the ECM for the new injectors.
My 06 Street Glide was in the shop three times for that problem before the bulletin came out. Once the bulletin came out they switched the injectors and did the download, no more problem.[/quote]
I have a 06 dyna that has the 8* injectors and was having the same issue that you describe but i was able to fix it with a fuel pak. Does the MOCO do this upgrade for free? What will the 25* injectors do as far as performance?
