Primary leaking from mid shift cap
Heres a couple of pictures. What would be the cause of thise.. According to the shop manual there is no seal there... at least from what i can tell. figured there would be one behind the cap but I cant see one there either, It just started today.
thanks http://i79.photobucket.com/albums/j1...imary2leak.jpg http://i79.photobucket.com/albums/j1...imaryleak1.jpg |
pop off the cap, i filled min with permatex "the right stuff" then put the cap back on... put a 2x4 under the kick stand and give it an hour or so to dry
Originally Posted by JRK5892
(Post 7157990)
Thanks bro! I havent had the time to look it over, just glanced this evening, and opened up the book. Had to run to "meet the teacher" for this school year. My son is in the 5th... wow! time fly's! Thanks again! |
what kinda bars are those Delta?
Originally Posted by mahagowitz
(Post 7158148)
Isn't that shifter hole supposed to be sealed by the tower gasket? See item 9 in the pic below of the primary
https://www.hdforums.com/forum/attac...lp-primary.jpg |
(Post 7157990)
1 Attachment(s)
Here is a picture of the "tower gasket", that fits between the inner and outer primary covers where they meet to form the tunnel the mid-shift shaft. Since there is no longer a shaft present to keep the gasket centered, it moves out of position and you get primary fluid leaking out the end of the tunnel.
I replaced the tower gasket and the leak stopped. You have to take off the outer primary cover to get to it. |
Originally Posted by coop creek
(Post 7158993)
Had the same problem here replaced the tower gasket, which had rattled out of place, but had to take primary cover off to get at so replaced that gasket too.
© 2024 MH Sub I, LLC dba Internet Brands
