Do you have the $99 Cobra 2 headlight?
Just installed the Cobra2 on my 2010 fxdwg. Install went well. I crimped the wires inside the dome which leaves it looking nice and clean. a few questions:
1 Should the position of the tilt be adjustable by hand after tightened?
2 Having a hard time getting the little bolt/screw (not sure what its actually called) under the front ring on bottom, to fit correctly. Should the chrome ring be recessed at the bottom or flush with front edge? (Chrome ring is a pain in the ****)
3 Also had to remove the cover for the fuse box and cant understand how to get the cover back tight.
these are probably dumb things, i thank you in advance...
Hand adjustability after installation is a tough one. Realistically, if you can adjust it by hand, it WILL need to be adjusted. Hard bumps, vibrations, etc. can move it if you are able to move it. Personally, I leave mine just barely adjustable, knowing full well that 1) I'm going to need to re-adjust it because it isn't tightened down hard, and 2) as I keep adjusting it, I'm eventually going to have to re-torque/re-loctite the nut since the metal will wear at each adjustment.
That set screw on the bottom is only to prevent the front ring from unscrewing itself. There are only a few threads available to it. Screw that that chrome ring down to full depth in order to keep everything behind it nice and tight (to keep rattles and breakage down). Note that I put a touch of locktite on that set screw to make sure it didn't back out since there are so few threads.
As to the cover, the only time I've had issues with it not being snug is when I keep trying to put it in backwards.
I only have a single allen set screw at the bottom of the light. Maybe you can post a pic to make sure we're talking the same thing?
For the tilt, star washers or lock washers can help that out (star is probably better in this case). Definitely don't torque it past the spec for the bolt (not sure what it is, but is probably in the service manual).
I crimped and wrapped them pretty tigthly with tape. If i have a problem i'll know where it is. Wasn't comfortable trying to solder inside the dome. Don't really have the tools or skills, lol...
Love the way the light works/looks. Next project begins tonight. Kuryakyn part 9064 which is 3inch extended forward controls, i'm excited...
