Best air intake
Oh.. and I beg to differ Foxster... tuning the runner length for the intake pulses, is just as important as tuning the exhaust for the exhaust pulses.
Once an air cleaner can flow as much as the engine can draw it makes zero difference on the dyno. Only for engines with a big flow (stage-3, big CC kit, etc) will you see any advantage of an A/C with a bigger surface area than the majority of good aftermarket stage-1 ones.
The only other exception I can think of is if you have a reversion pulse from a poorly tuned exhaust causing a big stand-off of fuel/air at the carb/throttle-body mouth. Then a long intake is important.
You will never find that on a dyno. The only slight difference you can get is with and without an air cleaner.
