So close to buy a Dyna, but there is one big turnoff.
HELLO
Was there any here that felt stepped on ?
I really want one, and has also accepted that they looks better than they drive And yes, i Have tried every single HD model.
But instead of you guys felt insulted. Could you then just please tell me why they chosed to build it like that way ?
Could they not just have made it like they have done with their Touring models. OR have I overlooked something, construction wise...
I really really want the Dyna, but I have to understand why I they made on that way.
I for one agree with you that it's a **** poor design. It baffles me why Harley designed them the way they did. But, in all but the most aggressive riding situations the Dyna handles very well. I should know, I've owned three. If you're looking for a really well handling Harley then search for a used FXR. With used Harley prices down, you can pick one up for a reasonable price.
Btw, if a Dyna's what you really want, then why not invest in a True-Track or similar stabilizer? It fixes the bad design.
[quote=22duke;8168470]HELLO
I really really want the Dyna, but I have to understand why I they made on that way.[/quote]
Why is grass - green, the sky - blue.... etc..because that's the color the Big Guy made it... If you must know WHY they are the way they are, maybe you should talk to HD engineering. They are the only ones who truly know "Why".
Rear Swing Arm
NONE of the Harleys are out of the box racers...Come on, it's a push rod overhead valve engine. Lots of other manufactures make faster and more competitive bikes and Harleys are a cruiser style bike. Every single car I ever purchased, had limitations and ANY vehicle you will ever buy will have to be adapted to. A Harley is no different...If the motor and suspension on a Dyna give you the *******, there is always BMW or better yet Bimota...go for it.
The Eagle Has Landed
Check out the all new 2011 Moto Guzzi California Black Eagle.
Moto Guzzi California Black Eagle is a motorcycle which was launched by Moto guzzi in 2011. The shape and design that is very interesting and remarkable. Motorcycles are classified as classical type, attractive design and durability on the engine by using 90 ° V-Twin, 4 stroke, with a capacity of 744 cc engine which is equipped with air conditioning. Suspension is perfect to give comfort in the drive because it uses Marzocchi hydraulic telescopic fork, Ø 40 mm at the front and swing arm in light cast alloy with two dampers, adjustable preload to the rear. Accurate braking system using a single stainless steel floating disc, Ø 320 mm, 4 piston calipers for the front and a single steel disc, Ø 260 mm for the rear. Please enjoy driving comfort with using these motorcycles.
The owner at the local Moto Guzzi shop said that our HD motors are mounted the wrong way. What's up with that?
I was going to say it Joe Dirt style, but you beat me to it. It just is! lol
