PC-V or V&H Fuelpak for 2011 WG? Help!
Switching out my stock pipes for some V&H Shortshots (black staggered)as well as the Sreamin Eagle Ventilator on my 2011 WG. I need some advice - should I go with the PC-V or the V&H Fuelpak? Is one better than the other? Advantages of one or the other? Help!!
I got my PC-V from Fuel Moto. Good price (beat every other price I was able to find online), awesome customer service, and ships already set up with a map for the specs you give them when you order on the phone. It took me about 30 minutes to install it, using the included o2 sensor eliminators.
You have the option of adding an Auto Tune module, so it will run in closed loop and tune itself using Bosch wide-band o2 sensors. I still haven't installed my optional Auto Tune module because I'm waiting to finish my 2-1 exhaust build. I'm working on that.
The PC-V performs exactly as expected. No need for a dyno tune.
I agree, the PC is a more rounded tuner, and going forward if you wanna do other mods or engine work, you can get a new map and your all set.
Plus, if they dont have the map you need, Dynojet will make one for you and its free.
PC all the way!
PC all the way!
