12" Fat Mini-Ape Handlebar Kit with Riser
Karsten
http://img217.imageshack.us/img217/3990/fbdone3.jpg
That’s the kind of look I would have on my FLD if I ever get it, (Oct.
The stock riser on the FLD will work w/chubby apes but you will need to grind about 1/8" @ about 45 degree angle off the bottom, outside edge as they will not fit otherwise. But you can do that without compromising the look as you will not see the grinds once the cap is bolted back on in place. If you don't like the above idea, then you will need a different top cap.
Harley’s
12" Fat Mini-Ape Handlebar Kit with Riser – Chrome
http://www.harley-davidson.com/gma/g...bmLocale=en_US
For the FLD doesn’t really show what exactly the risers that comes with the kit looks like.
I don’t want to use the stock FLD (pull back) riser anyway. I want the bars to line up
with the front forks.
Harley’s
The Risers that come with the HD kit are simply stock Straight 1.5 inch risers with what appear to be separate caps.
The 12.5 inch Chubby bars the dealer put on mine are part # 0601-0779.
Google search says they are Wild 1 Bars (note link was was a copy and paste and I have nothing to do with Axiom cycles)
http://www.axiomcycles.com/pages/ite...temsection=384
My dealer charged me $174.39 for the bars and used my stock FB risers and single piece cap.
I am sure you can find stock 1.5 inch Risers (straight w/o any PB) in the $30.00 range and either use you Upper Cap....Note, you may see some of the Knurling and what not of the 1 inch bar.
Or you can buy the Straight risers that don't turn out in the front....Hope you get what I mean there.
Hope that makes any sense
Karsten
