Dyna Vibration Problem
#42
#43
I had BAD vibration issues when i first got my used 06 superglide a few months ago. It was running LEAN so thay downloaded a 1550 map into it and that smoothed it out a bit. then i had it dynoed and the motor mounts changed. A lean running motor can be a vibration monster!
Well...it still vibrates, but now its what i would call a normal harley vibration...HOWEVER... it is cantankerous in that you may be in 6th at 70 mph and its smooth as silk one minute.....downshift.. pas a car.... up**** back to 6th at 70 again and its vibrating worse....
They didn't give me a copy of my map (a problem which i am trying to resolve) so i can;t tell where they have the o2 sensor reference voltage set at, but, i'm thinkin its set to produce stoich (14.7 or so) and THATS whats causing some of the vibration.
I'm gonna salp the Dyn OiED's back on it and see if it smooths it out.. if so.. i will have to get the copy of my map from the stealer expitied so i can go in there and bump up the o2 ref's
#44
#45
FYI......all the 07 Dyna models are set up to run LEAN by the Factory.... to meet the new EPA standards imposed by the Feds. That's another reason people are complaining about the massive amounts of excessive heat coming off the engine and their legs burning up. I cant imagine folks out in the western states, in the summer riding Dyna's in traffic. I suspect in 5 years, we'll be hearing about engine problems from the lean mixture settings and heat.
#46
Received 4,392 Likes
#47
I have a 2006 Super Glide with the same set up you have. SE11 pipes and air filter with ecm download from dealer. My bike vibrated as bad as what you are describing and my mirrors were useless. I got a pc111 fuel tuner and one of the unexpected benefits was the curing of my vibration problems. I can actually use my mirrors now. I guess my bike was just bad out of tune because it is very smooth now.
#48
My 07 Streetbob has the SERT and Vance and Hines short shots, A new front isolator and has been remapped' and I shimmed the front isolator. I have the same problem Buzzardbait has in 6th gear but it fees rough most of the time 75 to 90. It never smooths out. Great in every other gear now.
#49
#50
My dyna vibrates when I rev the engine. It seem like it is vibrating hard in the *** end. When I ride down the road, I can feel the vibration. What can it be? I have changed both mounts and doesn't seem to help. The back one I put Helo coils in them because I overtorked it. Should I just replace the rear again? Tires are up but because of the salt air, they are showing cracking. Not crazy but some. Should I also replace the tires?
