Aftermarket Quick Release Helmet Clips
Thought about the Echo but no manufacturer has adopted it and I can do the D-ring in seconds, subconsciously. No complaints here.
Now that I think about it, I've always used Shoei helmets and the strap material reminds me of a thick seatbelt. If some crap helmets use something thin or inferior, I could see that being a problem.
I've been using the Echo fastener on one of my half helmets and it does take some getting used to fastening and unfastening it. Since it's a half helmet I sometimes just loosen the D-rings and pull the helmet off without undoing it completely. For the most part though, I use it as intended but loosen the D-ring to make it easier to snap the Echo together, then tighten it with the D-rings.
Received 3,958 Likes
I got a Nolan helmet a few years back. It has a quick connect/release mechanism that is perfect.
Works well to, last year I hit the asphalt after flying 140 feet thru the air and it held.
If I ever went to a helmet besides Nolan I would mod the helmet with the Nolan connector.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
toastman, that's what I was saying, me and my gf both have the same problem with ligning it up sometimes. it's a pain when it happens. we have both had occasions when we thought it was fastened and while riding realizing that it didnt click like we thought and had came back out. that has only happened a few times but it only takes once at the wrong time. I dont see how some of you have never misaligned it and got it jammed up..... guess we're just not as good at hitting the hole on the first try. lol my friend has one and has the same problem sometimes as well.
My helmet has the annoying thin ones. Easy to put on, pain to get off. The guys I ride with all wear novelty helmets and are suited up and starting their bikes while im still tightening straps and getting gloves on. I ordered the Echo's on eBay: $7 and free shipping. I'll try em out and see how they work.
