Stage 1 Screaming Eagle and Xieds
I just oredered the Screaming Eagle Stage 1 Air Intake and I already have Screaming Eagle slip on pipes on my 2011 Dyna Super Glide. I also added Xied's which helped alot with heat. Now I am wondering if the Xied's will be enough for both pipes and A/C to prevent a to lean condition. I really don't want to spend more money on tuners at this time and I don't like the idea of splicing wires for the Dobeck TFI while under warranty. Anyone have both pipes and A/C with xied's?
I have the HD heavy breather with Rush slip-on's with the FL-VIED and just got it all together a couple days ago and I'm totally satisfied. I had decel pop before with just the Rush slip-on's and with combo I have now it's gone. Does it need a tuner and I will add it when I have the extra money but right now I'm happy as a pig in mud. Hope this helps.
EDIT: Ah I just Googled the FL_VIED and that is adjustable so it probably runs richer than the Xied's.
I messed with the adjustment on it and ended up in the middle which would be the same as the XIED.
I have the same year, model, and color of your bike. I have rush slip ons with the 2.25 baffles, big sucker open intake, And XEID's. The bike runs great but if I'm running at high RPM's and let off of the throttle quickly I'll get a little pop. It's actually think it's probably running a little on the rich side because in the summer heat I had no pop at all.
I'll eventually get a tuner but for now I'm just enjoying the bike and the added power.
