Jackyl - I need a tank lift...
He sells them on eBay
It states 3", but it will work with 2" (listed in the description)
http://www.ebay.com/itm/3-INCH-TANK-...ht_2801wt_1087
Received 3,953 Likes
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
There are many threads on this subject which should help you. Just research tank lifts and you should get what you need. I did mine awhile ago and don't recall everything I saw. I did have to remove my tank and do some rewiring.
My wife helped me with some, the zip ties did the rest. If you have a problem pm me.
I have the two inch from Jackyl and really like it, gay or not
A note of caution, your fuel gauge is gonna read waaaaay off after install, be sure to note where your fuel gauge is at BEFORE you install it so you can do the mental gymnastics to see what your fuel level is at.
Not that the gauge is that accurate to begin with..
