Want to make sure im going to order the right tires...please look.
Old 05-21-2012, 10:48 PM
hellbob37's Avatar
hellbob37
hellbob37 is offline
Default Want to make sure im going to order the right tires...please look.
Plan on going with Pirelli night dragons on my 12 FXDC.
Front 90/90h/21TL
rear. 180/60HB/17.
The alpha characters throw me off as there's another option for both tires in the same size. I did a little research and I believe the above are correct. Here's the alternatives.
Front MH90H/21
Rear 180/60B/17
Old 05-21-2012, 11:08 PM
DoomGloom's Avatar
DoomGloom
DoomGloom is offline
FXDC is a Super Glide? Unless you installed a 21 inch front wheel on your Super Glide, you should have a 19 inch wheel and the correct tire size would be
100/90-19. This is the stock tire size for the Super Glide and Street Bob.
If you want to go a little bit wider, you can get a 110/90-19 tire, that will also fit.
John
Old 05-21-2012, 11:12 PM
DoomGloom's Avatar
DoomGloom
Also, the stock rear tire size is 160/70-17.
The 180/60HB/17 tire will fit too, but you will have to make sure the wiring for the turn signals and tail light are tucked in good or they will get torn up by the tire.......
John
Old 05-21-2012, 11:38 PM
onemyndseye's Avatar
onemyndseye
onemyndseye is offline
Cant help you with the front but my NightDragon rear is labeled "180/60B/17"
Not sure of the difference in the 60B and the 60HB but mine fits a '09 FXD with no mods or issues.
Old 05-22-2012, 06:34 AM
hellbob37's Avatar
hellbob37
I am at least that smart. Lol. I should have said something about the conversion. Sorry Doing a wide glide conversion.i believe the H stands for the speed rating and the B means belted. Just didn't know if there was a reason to go with one as opposed to the other
Thams guys
dyoungblood357
03-28-2016 07:16 PM
Hessmonster
04-24-2015 03:08 PM
Superglide2012
09-05-2013 05:23 PM
burga1
01-16-2013 07:30 PM
magicsbikerdude
04-09-2007 12:47 PM
Quick Reply: Want to make sure im going to order the right tires...please look.
