"Cheap" 4 piston brake and full floating rotor upgrade on stock cast wheel
For my 07 FXD I got in the EBC MD516x full floating rotor for $138 online (Amazon) and had a Nissin 4 piston caliper off a Honda CBR1100. Any Jap 4 piston caliper (as long as it's not a "radial" mount) will do and are readily available on Ebay or Craigslist for under $100. I had Fabricator Kevin make me a bracket. (he has some for other Jap calipers like Tokico and Nissin readily available on his site and does great work and is fast and always answers the phone) I had a PM and a Jay Brake 6 piston caliper with the stock rotor and with the EBC rotor, and this by far stops way smoother and with more "feel" in the lever along with predictability. I still use the stock reservoir but, will be changing it just for S&G to a larger one. So basically you can upgrade your brakes from the crappy stock HD to great brakes for about $300.
well you hooked me... i have this caliper already just need the mount. i want to use the stock rotor as i already coated mine... that mount he made up for you would that work with a stock rotor? i just shot him a email to see if he could make me up a mount rather than me having to go through the BS of figuring this out myself hahahaha thanks for the post man this is great!!! i was about to tear apart my calipers for powder coating as it was, least this way i can do an upgrade as well!
I still support my Brembo bagger caliper upgrade over this as it cost less (depending on what you find) and has no need for an extra bracket. $200 for both calipers for me. Depending on the year of your Dyna and the size of the front rotor (11.8" is recommended) you might ant to do that too although it is not absolutely necessary. These calipers are day and night from the stock Harley's on my 2002 Dyna.
It is great to see another option as well.
