Roadawgz VS Laminar lip
Old 04-27-2013, 06:28 PM
07bobber's Avatar
07bobber
07bobber is offline
That's weird I don't get any noise off my quarter fairing. Have u adjusted it at all?
I have mine tilted forward a little
Old 04-27-2013, 08:48 PM
icecaps's Avatar
icecaps
icecaps is offline
Reading More Posting Less
Laminar Lip
-DynaMike- (09-15-2022)
Old 04-28-2013, 12:03 AM
EastBay_Solo's Avatar
EastBay_Solo
EastBay_Solo is offline
You need to adjust it. Mine did the same till I made some small adjustment. I added the roaddawgz pretty good with the wind and bugs lol .
Old 04-28-2013, 05:18 PM
Puglia10's Avatar
Puglia10
Puglia10 is offline
Yeah I had it all the way forward, then tried it in the middle, now tilted all the way back, and its a little better but still pretty bad. I'm curious if its because I'm short and ride in the win bubble (5 foot 7) I know a tall guy with the same set up and he has no problems either, but said its bad when he tucks down behind it...
I ordered a laminar so hopefully it fixes it.
Old 04-28-2013, 09:03 PM
kirby666's Avatar
kirby666
kirby666 is offline
here are a couple of the lip on my bike.
Attached Thumbnails Roadawgz VS Laminar lip-kirby-5-.jpg   Roadawgz VS Laminar lip-kirby-29-.jpg
Old 04-29-2013, 05:18 PM
Puglia10's Avatar
Puglia10
Puglia10 is offline
cool, thanks! mine should be here this week. do you guys find yourself looking through it all? was thinking of painting it solid black but maybe not if you look thru
Old 04-30-2013, 02:32 AM
Dynathrasher4life's Avatar
Dynathrasher4life
Dynathrasher4life is offline
Stage IV
Do You or anyone else have any pics of the two different roadawgs size windshields? Im thinking about the 13.5" but want to see what the two differences look like? And if the smaller one has that lip at the top curving up like tall one!
I decided when i got the 1
H.D. Quarter that i would get either the laminar or roadawgs?
Old 05-02-2013, 12:13 AM
bremsstrahlung's Avatar
bremsstrahlung
bremsstrahlung is offline
I have had all 3. The tall roadawgz, the short one and the Laminar Lip. I did not like the roadawgz at all. The material it's made of is cheap looking and flimsy. It's about half as thick as the Laminar Lip, therefore it shakes and vibrates at idle so much, it looks ridiculous on the bike. Worse still, the material they use and the manufacturing of it is hugely inferior to any other windshield I've ever had on any bike I've in 30+ years of motorcycling. The "clear" windshield is so wavy when you look through it, I consider it dangerous. Thats fine at highway speeds when your looking further down the road, but It's tall enough that you have to look through it at slower speeds and and I found it distracting to the point of finding my cornering lines disrupted. I still had buffeting with it and it looked like a cheap piece of c**p on my bike. It's sitting in my garage where it will stay. The shorter one and the taller one both have the same shape on top, by the way.
The Laminar Lip is a much, much better product. I've used them in the past on other bikes as well. It's crystal clear, heavy weight material and works well. I still sometimes get a small amount of buffeting with it, but only from the rear of my helmet where the air pocket starts to collapse, and that is mostly dependent on the ambient winds for that particular day. The wind noise is greatly diminished with it, too.
I also didn't like the adhesive mount it came with, the Dual Lock works perfectly.. it fact, it's really hard to get it separated after its together, I just didn't like the way it looked, so after I found a good height to mount it on the fairing, I went to Lowe's and picked up 4 plastic screws and wellnuts, 12 rubber grommets and 4 of those little snap covers to hide the screw heads and drilled four mounting holes through the Laminar Lip and fairing to have a cleaner mount.
HighonHarley (11-26-2017)
Old 05-02-2013, 11:49 PM
07bobber's Avatar
07bobber
07bobber is offline
Lets see some pics ^
Old 05-03-2013, 12:05 AM
DanDman's Avatar
DanDman
DanDman is offline
Anybody 6' 3" + running a Laminar Lip or Roaddawgz?
Quick Reply: Roadawgz VS Laminar lip
