Changing SE Heavy Breather to Joker Machine AC, will I need to re-map?
Hi,
Dyna WG 2011.
I will change my SE Heavy Breather to a Joker Machine A/C (looks and that I smash my knee in the Heavy Breather).
I have a SERT and did a Dyno when the Heavy Breather was installed.
Of course noone can tell for sure but give your best guess: Will I need a re-map? Can I drive another 1500 miles to my next service-interval and do a re-map then?
Dyna WG 2011.
Ok, I need some advice. I changed the AC to the Joker Machine, very easy swap.
When I opened the plugs covering the breather bolts on the SE heavy breather I had a lot of "clogged" oil in there, I guess that is kind of normal but it has never leaked anything out.
Now when I swapped, after taking a ride of about 50 miles when coming home and the bike cooled of I went out to cover it up and noticed that I got this "clogged" oil that had leaked out of the breather bolts. I had some oil spill that definetely had come out of the bolts.
I am not sure if this is what is called "blow-by"? Or is it other types of AC's that don't put the fumes back in the intake that has that?
Anyway, is this something that will get solved by a re-map? Get the air/fuel ratio exactly right for this combo?
UrbanRunner
10-13-2018 10:57 PM
