any benifits of a tank lift?
I go to the group that knows. What benifits are there to a tank lift, other then looks if any? Who's lift is better> and can i lift the rear of the tank to even out the FUEL GAUGE, WITHOUT modifying the seat, this is on a 13 FatBob, thanks, if anyone has a Photo, i'd like to see it.
Word is, the tank lift will allows better cooling over the top of the front cylinder and provide extra flow to the rear.
Other than that, just the looks. Mines a DK Customs 2" lift. The DK version is a set of "Z" or "S" shaped posts. Mine are powder coated black.
There's another version made from shaped sheet metal. I haven't tried them. My DK kit has never worked loose., is easy to install and it looks good.
Your mileage to reserve-light will be less. The tank holds the same amount of fuel, but you may lose access to about 1/8 of a gallon.
Received 3,953 Likes
https://www.hdforums.com/forum/vendo...ed-weekly.html
We think ours is better. It is purpose made, it matches the round frame, is definitely stronger than flat stock.
Yes, you can do the Deluxe option (rear lift) without modifying the seat...it is a tight fit, but will work.
Besides not trapping the heat, it lets more of your engine show, and is easier to clean. Less air flows over the top of the tank, so with some it helps reduce/eliminate buffeting.
__________________
Kevin
Gear Up & Ride in! DK Custom 4th Annual Open House, June 8th. 🏍️ Click HERE For The Lowdown.
DKCustomProducts.com
Kevin
I agree with the loss of maybe 1/8th of a gallon. I recalibrated the fuel gage after I installed the lift so my reserve light comes on with about 1/2 gallon left.
There is another thread on here detailing the rear lift. The only mod they made to the seat was bending the metal tab that inserts beneath the rear of the tank.
