Quick, easy, powervision question
I've seen a lot of posts touting the benefits of the powervision for its adaptability beyond a stage 1. I plan on doing cams and big bore in the future, so I'm pretty set on picking this up for my stage 1. The only question I have is, do I need to mount this thing to the bike at all times or can I just flash, probably run with it on for a little bit to get some data and adjust the tune as needed, then pull it off and store it away?
Originally Posted by CowboyIp
(Post 12552117)
Ok, great. That helps settle out the stage 1 to a Supertrapp 2-1 Supermeg, Powervision, and an Outlaw 587 air cleaner.
if I may ask, how do you download a map into it, do you still need a laptop for that?
to put a downloaded map you need to connect it to a windows computer with a usb cable and run the winpv software.
once its downloaded you dont need to plug it in again. except to update firmware or download another map. or archive a previous map. i always keep a copy of the stock map. i keep mine in my saddlebag while im tuning (make sure the cable is nowhere near the belt) . and when im not its in the box on a shelf. if you get it from fuelmoto and tell them what your doing they'll send you a decent base map. after that you'll want to run a few autotune sessions to dial it in. i consider an autotune session a full tank of gas in mixed conditions. |
Originally Posted by iwantalowrider
(Post 12552604)
and get it from fuel moto. jamie is top notch and has the best customer service if you ever need help with the tuner. not to mention free fuel maps for life. just save your receipt with order number
© 2024 MH Sub I, LLC dba Internet Brands
