PLEAE HELP 2009 FXDF won't start
Hello everyone, I just got this bike last weekend and have been riding it all week without problem. I went out for a ride today and noticed my check engine light on and the bike was running really rough. I pulled over tried checking the plug wires and ecm codes. The only codes I'm getting is 107 and 122. I got the bike back home, and now it wont even start again. It turns over and backfires. I have been searching and cannot figure out this problem! if anyone can point me in the right direction it would be much appreciated!
Originally Posted by kainvamp
(Post 13025584)
P0107 Map Sensor Open/Low P0122 TPS1 Low Take the air cleaner assy off and inspect your Throttle Position Sensor and do the same for the map sensor. That's just to see if anything is broken, disconnected or possibly come loose. You say you haven't had it long? |
Well I don't know what the problem was exacly, I took a lot apart including the gas tank console apart, checked the map and tps sensors, which were fine on a volt meter. Inspected all wiring behind the electrical box, put everything back together and the bike started up, no check engine light. The only codes I have now are for the lack of o2 sensors, which I don't have hooked up. I rode the bike a couple miles, runs awesome. I don't know, either I fixed something putting it all back together, or it was PFM. Either way I'm relieved my bike is fine. Hopefully it stays that way!
Do you have a fuel manger?
Like a PCV, etc... Moisture will do the exact same thing. If you do did you use dielectric grease? if not use it. |
© 2024 MH Sub I, LLC dba Internet Brands
