"Lifters" Like a damn oil thread maybe worse
Old 08-27-2014, 12:37 PM
slyedog's Avatar
slyedog
slyedog is offline
Default "Lifters" Like a damn oil thread maybe worse
I have been off work for a few weeks and can't ride yet due to injury. Getting the stuff gathered to do my cam install and the lifter question popped up. What to use. Keep stock "c" which have been proven upon research to be junk per opinions, go high dollar like woods or s&s premium, tons of other brands that go on and on. After extensive research I chose Gaterman 1023s.
Wish they were mad stateside but none the less seems to offer best reliability and oiling functionality per numerous threads of research for the price. Cost was $140 for set from a local supplier. One other nice thing with the Gatermans is they only have one flat so no worry about installing wrong way. Just thought I would say that like oil threads, if you are looking at lifters for your cam install, plan on a headache of research, or find some, buy them, don't think about it and hope for the best.
Old 08-27-2014, 01:42 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Just about all the aftermarket lifters seem to work well, really have not heard negative experiences other than some of the stock HD stuff.
Old 08-27-2014, 07:09 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
I run Gaterman 1023's in my bikes and have had zero problems. They came highly recommended on another more performance related forum. A lot of the high performance guys like them a lot.
The C lifters are generally acknowledged to be junk, with many failures reported.
Old 08-27-2014, 09:06 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,031 Likes on 652 Posts
I have gaterman's and johnson lifters. A lot of people like feuling ones too. But then again I have never had a problem with the stock lifters either
Old 08-28-2014, 08:07 AM
slyedog's Avatar
slyedog
slyedog is offline
As nhrider said the Gatermans have a solid record behind them. I got them from a local builder known as King of Cubes. Seen and heard of major builds from him and his continued use of them convinced me.
Old 08-28-2014, 08:35 AM
californiafatbob2013's Avatar
californiafatbob2013 is online now
Default Lifter's.................
Just had to say I am glad you decided to put new lifter's in with your cam swap, very good idea.............
I pulled all my stuff apart last night for my cam swap and found that HD had the two front lifter's in backwards.......... Go figure.......... I was wondering why I had some pre-pump up noise on cold start........!!!!!!!!!!!!
I went with the S & S base line lifter's, did not hurt the wallet and much better than stock HD 99C's...........
Good luck with your cam swap ..............
Live Free = Ride Free............
Old 08-28-2014, 09:15 AM
TNCarters's Avatar
TNCarters
TNCarters is offline
Lifters are a common subject on the CVO forums as several members have had lifter failures take out the entire engine in as little as 20,000 miles. I know the 110's have a bit different head and valve setup but sad when a $50 part takes out a $5000 engine right at the end of warranty. HD has to quit cheapening this stuff to save a buck.
stilup
12-23-2015 10:56 PM
timberland
Exhaust System Topics
14
03-24-2013 10:59 AM
Old Gunny
21
05-16-2012 06:51 AM
aflstn95
04-19-2012 09:45 PM
FLTR2008TRIKE
11-29-2009 10:43 AM
Quick Reply: "Lifters" Like a damn oil thread maybe worse
