speedo dont work signal wont cancel
I have a 2000 electra glide classic speedo does not work it lights up moves alittle bit when you hit the switch but does not register going down the road odometer also does not work turn signal don't cancel and radio stays at same volume I have changed the speed sensor no change changed the tsm no change I have been thru this forum many times and still cant figure this out I have checked voltage on red wire for the vss no volts checked continuity on red white and black they seem fine need some help is it my speedo ? its what the book says but I still question it help please .....................thanks dan
