Lights Going Dim
Old 04-29-2017, 04:54 PM
norman3516's Avatar
norman3516
norman3516 is offline
Default Lights Going Dim
i just got a 2009 rocker c with 14000 miles . i rode it to work this morning when it was still dark and my headlight and all the lights go from bright to dim every few seconds , likes its going from 12 volt to 6 volts and back to 12 volt over and over all the way to work ,no engine light or any trouble lights are coming . anyone have a idea what it may be doing this ? thanks norman
Old 04-29-2017, 05:04 PM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is online now
Received 2,227 Likes on 1,410 Posts
Stator or voltage regulator shitting out on you. Troubleshoot the VR first.
Old 04-29-2017, 08:44 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
First charge the battery and have it load tested.
Clean all battery cable connections.
Once these are good, then you can troubleshoot the charging system.
Old 04-30-2017, 06:07 PM
norman3516's Avatar
norman3516
battery is good , 12.76 on the meter
Old 05-01-2017, 11:14 AM
norman3516's Avatar
norman3516
its the voltage reg. i put the meter on the battery and it was 12.75 then i started the bike and it drop to 5.5 then 3.2 never went up past 10 volts . thank you for your help
Old 05-02-2017, 09:54 PM
Vernal's Avatar
Vernal
Vernal is offline
Received 7,308 Likes on 1,907 Posts
A battery that drops below 9.5 v starting is not considered good.
Do what Dan suggested and charge the battery and get it tested.
Annsporty82
11-28-2017 09:02 AM
rider718
08-18-2014 08:52 AM
BungoBill
EVO
08-20-2011 12:37 PM
jhughes484
09-14-2008 10:15 PM
locoman77373
05-25-2006 01:18 AM
Quick Reply: Lights Going Dim
