Flickering Lights
Old May 24, 2006 | 12:22 AM
locoman77373's Avatar
locoman77373
Stage II
Default Flickering Lights
I have an 05 RK FLHPI. Recently while idling I've noticed all of the lights dim, and when I Rev up the engine the lights get brighter. Is this normal. I've only had the bike a few months. Can someone please give me some idea of what is going on, or what may be causing this?
Thanks to all in advance.
Old May 24, 2006 | 12:24 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Flickering Lights
Check your battery connections first.....
Clean and tight.....
Then check your connections at the stator and voltage regulator.....
Old May 24, 2006 | 12:25 AM
bay13's Avatar
bay13
On the surface it sounds like your alternator/regulator may not be putting out whats needed. I'd have the system load tested to make sure yours is putting out the amps it should. Sometimes a bad battery can drag down an alternator as well.
Old May 24, 2006 | 01:50 AM
Pat's Avatar
Pat
A friend's dad used to say that 90% of the problems in the world are caused by women, the other 10% by dirty battery posts. Clean the battery posts and check all the connections. If that don't work- then start looking into the charging system.
Just like what Bob says.
Old May 24, 2006 | 10:56 PM
jube455's Avatar
jube455
Do the simple things first. Check battery connections, the two ground connections under the seat, etc...
In the past I've f*cked away hours looking for a bad connection, while the whole time it was a fuse. Don't tell my boss that.
Old May 25, 2006 | 01:18 AM
Toytech's Avatar
Toytech
Sooo... How many miles on your ride? Most likely a bad connection or a bad ground. Yes check your battery post connections then follow the cables to where they bolt down and check them also for corrosion and loose-ness. The reason I ask about the milage is the 8000 mile regulator/module failure that is sooo common on modern Harleys.
Joe
Stroked sportster
Aug 24, 2016 07:03 PM
rider718
Aug 18, 2014 08:52 AM
rekesbass
Sep 12, 2010 12:24 AM
Storm2u
Jul 15, 2010 02:22 PM
jhughes484
Sep 14, 2008 10:15 PM
