Charging issue...
Old Jul 14, 2010 | 06:38 PM
Storm2u's Avatar
Storm2u
Stage II
Default Charging issue...
1991 Sporty 1200. Running with lights on drains battery, dumps engine. While still rolling at speed with engine off, slip clutch to restart, turn lights off at ignition key, she stays running and I can get back home. Garage tests: With engine off, battery reads 12.7VDC. With engine running, lights off, battery registers 12.4 - 12.6VDC. With engine running, lights ON, voltage across the battery drops to 11.4 - 11.9VDC. When I rev it, the voltage drops even lower. I'm thinking voltage regulator/rectifier. (They ARE integrated, aren't they?) Any thoughts. e-mail: futurebtmfdr(at)yahoo(dot)com
Thanks in advance,
Storm
Old Jul 15, 2010 | 01:14 PM
95custmz's Avatar
95custmz
First, put your battery under a load test and make sure it does not have a dead cell.
Old Jul 15, 2010 | 02:22 PM
2KSport's Avatar
2KSport
If you rev and voltage drops i'm saying no charge. I would check all conections first then reg.,and stator.
rider718
Aug 18, 2014 08:52 AM
Constantine77
Mar 27, 2013 10:37 AM
rekesbass
Sep 12, 2010 12:24 AM
jhughes484
Sep 14, 2008 10:15 PM
locoman77373
May 25, 2006 01:18 AM
