No Low Beam. Only High Beams
2005 883 Sportster.
I only have high beams. When i switch to low beams, the high goes off but the low doesnt go on. I disconnected the connections, checked for continuity between the harness's, and have that. New bulb, checked for 12 volts on the yellow low beam wire at the harness, and nothing. Could it be the handlebar switch?
How can i check that?
Jrindagame
Electrical/Lighting/Alarm
11
04-22-2014 05:56 PM
