97 elecrta glide classic, when using the turn signal, only the bulb on the speedometer will dim when using the turn signal while flashing. Any ideas why?
Bulbs get their power from the same source wire, how about the neutral light, dose it dim when your run the turn signal? How is the state of charge in your battery, is your stator putting out enough power? Is the Voltage Regular operating correctly?
