fuel gauge inop, miles to empty shows dashes
Hi
A couple of questions. 2011 FLHX /103. Recently the speedo miles to empty stopped and only shows dashes in the window. Speedo and trip odometer work fine. Low fuel level light is on. Fuel gauge no longer shows a fuel level, just stays on empty.
I am assuming that the fuel sender in the tank has gone out. But wanted to make sure the gauge itself has not failed. But I wasn't sure if the MTE feature feeds off the fuel gauge. So to be clear, does the MTE display feed off of the fuel gauge, or directly off the fuel sender?
Thanks in advance for any help!
