2005 FXDWG - unneeded turn signal wiring
I’m installing an Eagle headlight with integrated turn signals and plan to remove the stock turn signals. I will connect the turn signal feed wires to the turn signal wires of the integrated headlight.
Power and ground will come from the headlamp so i don’t need the existing ground and power from the stock wiring, right? What should I do with those unused four wires (one blue, one black wire for each signal)?
Do I remove all the way? Tuck them away? Connect with something else?
Wire diagram from manual. Both turn signal wires are violet on my bike, so not violet and brown.
https://www.thumpertalk.com/forums/t...-a-better-way/
Matt115
03-31-2006 04:13 PM
