No Spark Rear Cylinder
I have 1200 XLC (2001). I have not rode much this past summer, but I recently pulled it out to go for a spin. It rode okay, but I did notice it was missing at idle. I parked it and today I went to start it and it was missing really bad. I checked the spark and I am getting no spark or a weak/intermittent spark at the rear cylinder. I changed both plug wires and the problem persists. I checked the spark at the coil and the front is sparking, but the rear is not. Is it unusual for a coil to go bad and only one side sparks? Could the problem be in the ignition module?
I have a HD repair manual for this bike, but it does not cover a single cylinder spark problem. In fact, the test for the coil is whether or not it sparks. Fact is, it is sparking, just one cylinder, though. This Sportser uses a dual spark ignition in that it sparks simultaneously for both cylinder. Any advice to test components would be greatly appreciated.
Here is what I have done so far:
*Checked resistance on primary and secondary coil. They are within normal limits, but on the low side.
* Cleaned and re-gapped plugs (they are fairly new with less than 500 miles on them).
*Checked power to the coil with ignition on. Primary supply is fine.
* Replaced both plug wires.
Any help is greatly appreciated. Thanks.
i just "***-u-med" that was already done.
swap your plug wires at the plugs. if the problem switches to the frt cylinder then your problem is either the coil or ignition module.
if that doesnt' work, put them back the way they were. now swap the wires at the coil. if the problem goes to the frt cylinder then your problem is either a plug or a wire.
there are a ton of posts on here on how to check the ignition module and coil.
Last edited by UltraNutZ; 11-14-2010 at 03:41 PM. Reason: hadn't had my coffee yet! :-)
