speedometer buzzing/clicking/humming - but not working
Can anyone please help - electrical is not my strong suit....
While riding my speedometer began to sweep the dial eratically and then fall to zero.... this happened intermittently during the ride.
when I arrived home and parked - the following symptoms are present:
PLEASE help this issue has dragged on since last riding season.
- when key switch is OFF - the speedo clicks, buzzes, hums (I say it hums but a case can be made for any of the three if you listen closely enough)
- when the humming is happening the needle "pulses" like it is trying to move (moves the equivilant distance of 1 or 2 MPH - BUT stays below the "zero"
- when the key switch is "ON" the humming/buzzing/needle moving etc STOPS - BUT the odometer does not come on.
- I assumed a speedo issue so searched until I found a replacement - I installed the replacement and it does EXACTLY the same thing.
- pulling of fuses has NO EFFECT on these symptoms
- when I disconnect the speedo the bike seems to run fine (other than no auto blinker cancel, no speed indicator, no odometer etc - mening enginewise it seems to start, run, etc)
