96" build with Marelli EFI
It's a 95" build if its Big Bore from harley or it can be a 97" or 98" if its from S&S or Hillside, etc.
As for mine, its a Stage II 95" MM injected Stage II big bore with about 85 HP and 95 Ft/Lbs TQ, I just passed 150,000 miles on the motor (I did install new heads back at 75,000 miles,) and the bike still runs excellently which speaks a lot to its reliability.
Stick with the MM. It has its little quirks, but once set right leave it alone..... I've been tinkering with mine getting it to run right. Just a suggestion, if it hasn't been done yet look at changing your fuel lines to the goodridge lines. My factory lines (not rebuildable but the goodridge ones are), were driving me crazy, leak one minute, then wouldn't have any issues for a month, then dump a gallon of gas everywhere, then wont leak for another month...... Best $150 I have spent on the bike. Fuel leaks will drive that MM crazy.
Mine is an EVO, and when it is tired I want to build a 89" for it. Keep us posted on how it works out!
Any ideas on the injectors?
Interesting. I havent had any leaks with the MM so far. I don't even know where to look to find replacement parts for this thing. I've thought about upgrading the injectors but I can't find them anywhere. I have the red ones, but I've heard the green ones work better. My MM works amazing at the moment. I was just concerned if hamper the results of my build, but according to most on this thread it won't be an issue at all. Thanks for the input.
I personally love the MM, since everyone tells me that it can't be done....
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I have SS Power tune duals with crossover (Excellent pipe btw), Ness big sucker, and a pc3 usb. So far so good, but I haven't really done anything serious to the motor yet. Thanks for the input!
On a side note. You guys that are getting 100/100 or at least close to it...what exhaust are you running. I know with duals you get a bottom end drop but with the SS power duals the crossover is supposed to prevent that.
I know 2 to 1 is best but not my first choice. Any advice on slip ons? Rinehart 3.5 with the high flow baffles sound great. I have the 2.25 baffles now. A little quiet but if they help with bottom end then I may just keep them in.
So what are most of you running?
Also sorry for rabbit trailing this thread!
