Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Yesterday I was riding and noticed my bike had a low speed hesitation. Just cruising it would stutter or miss but under full throttle it performs great. When it stutters it has a slight pop in the pipes. Any help would be great.
Some bikes have had a problem with the fuel line in the gas tanks getting a hole worn thru them. Only way to tell is to take it apart and look for it. If that's the problem, you'll need a new hose. You can slide the old hose over the new one' to prevent it from happening again.,,
