Woods 999-6A Cam? Anyone?
  #121
Old 11-23-2015, 12:16 PM
springers4ever's Avatar
springers4ever
springers4ever is offline
Cool Crank Gear
One might run that cam with a +4 degree crank gear and enjoy a little more Tq. in the mid range , on a stock motor ...just be sure to check all clearance's ..but then that would be a 777 ,with longer duration ....now that might be something !!!???
  #122
Old 11-26-2015, 11:55 AM
wscott's Avatar
wscott
wscott is offline
Originally Posted by WG2011
Was chatting with fuel moto and they said this is the cam to go with for a bolt in on the 103 Rushmore. Looking for anyone who maybe running this cam with some insight. (More than likely going to use it on my 2015 street glide special.) Or for the cam guru's out there here are the specs.....
Open Close Lift Duration TDC Lift
INT 26 46 .575 252 .230
EX 46 26 .575 255 .225
http://www.fuelmotousa.com/i-2085965...ECIAL%20FLTRXS
Man,252/255 (IF THATS DEG DURATION @.05) is a ton of duration & overlap which is a bit too much cam for best perf if your motor has less then a minimum of 10.0 compression,it would work in that case but not optimal if comp is less then 10.0 at a minimum.
Scott
  #123
Old 11-27-2015, 09:45 AM
WG2011's Avatar
WG2011
WG2011 is offline
Boys love the convo and info but I ended up picking a different cam anyway. Thanks went with a recommendation from a local builder/buddy waiting to get the final tune numbers as we speak. Kuryakyn crusher 24d. Numbers should be somewhere like 104hp 108tq
  #124
Old 11-30-2015, 07:20 PM
junglejoe's Avatar
junglejoe
junglejoe is offline
Cams cams cams... We are all(well most) after that thumpity thumpity thump thump thumpity thump.. Science works way better than magic, You want the right package he first time, and all the available horse power for what you have, call Scott at Hillside!
  #125
Old 12-01-2015, 05:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Thanks for the kind words junglejoe!
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
  #126
Old 12-01-2015, 05:29 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,118 Likes on 1,341 Posts
Had a couple customers ask recently about this thread and the differences between the TW-999-6 and the TW-999-6A so I'm adding the info below from another relevant thread:
For reference the dyno chart below is a direct comparison of the Wood TW-999-6 and the TW-999-6A in the same motor on our 2015 Road Glide test bike. This motor is a 107" @ 10.75 compression with FM Level B CNC heads & FM E-Series 2/1 exhaust, tuned with Dynojet Power Vision. Note these runs were done a day apart.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
  #127
Old 12-02-2015, 05:58 AM
Hillsidecycle.com
Sponsor
Cyclerama .575 will push off more torque, as will a T-Man .625, and Wood 400.
No pork, without torque.
Scott
  #128
Old 12-02-2015, 08:06 AM
ntraindavefl's Avatar
ntraindavefl
ntraindavefl is offline
Ha! True all that....pork is good...torque even better.
  #129
Old 01-10-2016, 05:24 PM
OnTheFence's Avatar
OnTheFence
OnTheFence is offline
The school of Hard Knocks and money pissed away comes into play here. Speaking in a general sense, who knowingly wants to buy a set of cams that leaves them with a useless bike below 3000 rpms? I am guessing no one wants to volunteer for that.
The 777's suck on a stock 103. I would suspect the 999-6a is the same. If a cam has an optimum compression range, post it in the advertised specs and move on.
  #130
Old 01-19-2016, 04:12 PM
scj's Avatar
scj
scj is offline
I'd like to see the 117" Harley drop in cylinders matched to the 999-6A cams in a CVO with headwork.
Quick Reply: Woods 999-6A Cam? Anyone?
